Service entrance cable question
Will 4/0 4/0 4/0 Aluminum service entry cable fit into a main lug 200 amp load center. The load center is a main lug with no main circuit breaker but i have a circuit breaker on the power pole below the meter. The load center is rated for 200 amps its a 20 space 40 circuit box. Thank you.
Yes.... the 4/0 will fit the lugs.
However, you are required to have a disconnect also at that sub panel since there are more than six breaker spaces.
Has any one hooked up an Eaton 200 amp mqin lug load center 20 space 40 circuit? I know the 2 hot cables go into the middle at the main lugs but the way this panel is set up is different than any others ive ever hooked up. Can some one explain to me where my neutral and my ground cable hook up. Woukd like a diagram also if you can. Please help me with this panel. I cwn find information on every other panel except this one.
Received 273 Upvotes
There should be a neutral bar. Also as mentioned if this panel is after a disconnect (and it should be) you need a ground wire and will need to add a ground bar and isolate the neutral bar (remove ground strap/screw) from the case.
