Putting back Half Hot Outlet while adding another outlet
Old 02-11-17, 06:10 PM
E
Hello All,
I'm in Southern California, USA.
I'm a super noob at DIY electrical, but wanted to see if I can take care of this myself.
When I first moved into this house, there was a "half hot" switch, that controlled one of the Outlets on box located on the ceiling by the Garage opener.
Sometime later, I had a family friend (he was an electrician, but no longer around), who added another Outlet box on the right side of the garge, but he got the power source from the box on the ceiling. When he did this, he rewired the Outlet so it's no longer a Half Hot.
Now, I want the Half Hot back, and I also want to keep the new outlet on the right wall.
Can you see attached photos, and let me know if it's correct?
http://imaginesd.com/overview.jpg
http://imaginesd.com/how_its_wired_right_now.jpg
http://imaginesd.com/would_this_be_correct.jpg
Any help is appreciated
Thanks!
Eric
Old 02-11-17, 06:28 PM
pcboss's Avatar
Received 92 Votes on 79 Posts
Check to see if the tab on the brass side is broken. Was any work done at the switch?
Old 02-11-17, 06:54 PM
E
Yes, the tab is broken...but both outlets are hot full time.
Old 02-11-17, 07:00 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Is power currently running to the switch first? Please post a picture of the switch wiring. http://www.doityourself.com/forum/li...rt-images.html
One flaw in this is no mention of GFCI protection that is now required in a garage. Is this on a GFCI breaker? The ceiling receptacle must be fed by a GFCI protected source. It can not be GFCI because a GFCI can not be split and it is too high for GFCI accessibility requirements. A breaker isn't the only way but if you want to meet code some changes from the original wiring may be required.
Old 02-11-17, 08:15 PM
pcboss's Avatar
The box is too small for that many wires and it is an extension ring. It should have a back to prevent the spread of any fire. It should be changed to a larger box.
Old 02-13-17, 09:24 PM
E
This was a brand new house (built in 2002), and the box at the top (where the garage opener is plugged into) was there from the start. Now, I did look today, and there is a GFI outlet on the wall which I think that power is being sourced from.
As for the switch, I know this may not help, but here's the pics:
http://imaginesd.com/switch.jpg
Thoughts?
Old 02-13-17, 10:09 PM
ray2047's Avatar
This is one way it can be done if power from the other GFCI you found goes to the overhead receptacle. You need to verify using a multimeter if that is the case. You need to disconnect each 2-conductor cable at the ceiling receptacle and measure between black and white. The reason I question it is because while what I have drawn based on what you have written will work it is not the most logical way to do it.
