Switch not operating outlet. Outlet hot all the time
Hi Everyone!
Brand new to the forum, but I've had some problems solved by the responses I've seen here!
I just moved in to a house and have this problem:
The light switch in the downstairs bedroom does not do anything. The closest switch I'm assuming it's supposed to control is hot all the time. I haven't changed anything, this is how it was when I moved in. See the pictures for the wiring. Is this wired correctly? Could the switch be bad?
Thanks in advance for the help!
Welcome to the forums.
We don't recommend using the "push-in" connections on the back. The side screws give a better connection and are more reliable.
Make sure the bridging clip is removed from the screw terminals on the brass side where the red and black wires are.
Since that is a plastic switchbox..... there should be a ground wire attached to the switch.
That appears to be a three way switch (black screw) but I only see two wires connected to it. Are there three terminals not including ground. There should be a second switch if it is a 3-way.
First though check the receptacle. Has the tab been removed between the brass screws.
