Wiring bathroom to code
As part of my snowballing project of simply removing the carpeting in my bathroom, I noticed the following;
14-2 line from breaker box (15a) to 3-gang box.
Gang box to 1) center light, 2) center vent, 3) vanity light, 4) GFCI receptacle
Pretty sure this is not up to code if only because it's on a 15a breaker (and uses 14-2). Even if it were code, I'd like the receptacle on a different breaker since I have the room in the box.
May 1;
1) Keep 3-gang the way it is, and have a separate 20a to the receptacle?
2) Considering future upgrades; Run 20a to 3-gang, keep the 14-2 to the switches (and lights), run separate 20a to receptacle?
3) lazy approach, but I'd like to know; keep all bathroom wiring how it is, but use 12-2 and a 20a breaker to get to the 3-gang box?
While I'm asking questions; is there a mnemonic device to remember which is Line and which is Load?
Thanks
May 1;
Thanks
Probably was up to code at one time,no real need to change it,however you could bring a 12/2 to the box and connect the GFCI receptacle to that if you like assuming the conductor fill in the box would be OK
Geo
Geo
I certainly hope that it was code when installed.
My main concern is that this is a rental unit and the breaker box is in the sort of basement that my fiance would never enter. I wouldn't want the entire bathroom dark just because someone wanted to use a hairdryer. Since I'm already opening up walls, I'd like to allow for future install of a vent with heat.
To verify;
12/2 20a to the gang box with 14/2 for switches AND GFCI is fine?
If I wanted to;
12/2 20a to receptacle is fine
separate 12/2 to gang box with...
a) 14/2 to vanity lights
b) 14/3 to exhaust and light
d) ??/2 to the heater part of exhaust/light
OR, does the heater need its own run to the breaker box?
I don't really want to tear apart my ceiling, so I might not actually run a new line for a heater. But I'd like to know what is needed if I ever do.
Thank you
To verify;
If I wanted to;
Thank you
14/2 to switches/light only if on 15a breaker. So new 12/2 on 20amp just to GFCI receptacle.
Combo fan/heater is fine on 15a circuit with 14/2 as long as there is no receptacle on same circuit. Technically not allowed to have vanity lights on same circuit if heater is over 50% of 15amp load.
Note some combo light/fan/heaters specify a 20 amp and/or dedicated circuit in their installation instructions. This supersedes code. And if 20amp you need 12/2, sometimes two 12/3s to feed unit from switch box to get light/fan/heater/nightlight. If over bathtub may need gfci depending on instructions. GFCI breaker or dead front.
Summary: 3 circuits recommended. 20a to GFCI receptacle, 15a for vanity lights, 15 or 20a for heater/fan
You could leave the lights on this circuit and add a 20 amp circuit with 12 ga wire/cable but you cannot use 14 ga wire on a 20 amp circuit so your plan will not work.
If I were to run a single 12/2 20a to a gang box, all the wiring from the switches to the fixtures must also be 12/2? This seems a bit odd since most of the wiring in the fixtures themselves are 18 gauge or thinner.
Thanks
Does the heater fixture generally state amp draw?
The heater may just state the wattage. To get the amps, divide the wattage by the voltage.
