Is this the normal setup for an outlet
Old 02-20-17, 12:27 PM
K
I was trying to plug in a new to me fridge in my garage but it never kicked on. The outlet had been working previously but since I tried plugging the fridge in it has not worked since. When I was trouble shooting the issue I pulled the outlet out and this is what I found.....
It didn't look right to me, but I have very little electrical experience.
Old 02-20-17, 12:45 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
The one problem I see with the receptacle is the wires are stabbed into the holes in the back of it. Remove the power and twist the wires back and forth while pulling them. They will extricate themselves from the holes. Then strip back 3/4" and put a shepherd's crook on the wire and place them under the screw heads. White to silver and black to gold. Stab back connections are fairly unreliable.
Once you have done that and replaced the receptacle in the box, power it up and check the receptacle for power using an inexpensive multimeter.
Old 02-20-17, 01:07 PM
A
Received 73 Upvotes on 66 Posts
Twisting while pulling works but they're sometimes stubborn, so if you have a second hole next to the holes that the wires are in, you can press something into it to release the internal grip. A stripped piece of 14 gauge copper wire works perfect for this.
Old 02-20-17, 01:24 PM
K
Well I don't own a multimeter, so what I did was plug in a candle warmer. When I plugged it in it did not turn on. When I was removing the stab back wires some of the wires broke inside the ports. Would that cause issues that I'm not thinking of?
Old 02-20-17, 01:30 PM
Received 3,982 Upvotes on 3,574 Posts
It looks to me like a single white wire on the neutral/silver side and a white and two black wires on the hot/brass side.
When I look again it must be an optical delusion.
I don't believe your problem is there. I'd say it's at a receptacle before that one.
If the wire snapped off.... just strip it back and form a new hook.
Old 02-20-17, 01:35 PM
K
Well that's no good, this is a rental home and I have no idea how they wired the place.
Old 02-20-17, 01:44 PM
Then you need to contact the landlord. There is a fine line with liability issues in rental units.
Old 02-20-17, 02:35 PM
W
Received 63 Upvotes on 55 Posts
Receptacle
Could the receptacle in the photo be a back wired rather than a back stabbed?
Look for a tripped GFCI receptacle upstream on the same circuit.
Old 02-21-17, 08:15 AM
K
I checked all the GFCI receptacles and wasn't able to find anything.
