Hoist control wiring help please!!
Old 02-26-17, 06:08 AM
P
Hello all,
I'm hoping some clever person can please help me...
I have an electric hoist set up and I would like to have another one to lift at the other end. I don't really want to operate 2 remotes so I want to wire them both into a terminal block and then into 1 remote....
That sounded simple in my head, until I opened both remotes to find the internal wiring was different!!
Both are from the same retailer but several months apart so I guess the manufacturer process changed.
Anyway, here are 2 pictures of the internals. Picture 1 (0612) is the remote I want to operate both hoists from but see what I found when I opened remote 2 in picture 2 (0613).....
Can anyone please tell me which wire's in pic 2 to connect to the wires in picture 1 so I can use just 1 remote?
Thanks,
PName:  IMG_0612.jpg
Old 02-26-17, 06:35 AM
P
Received 205 Votes on 173 Posts
Pulling the load of two hoist through one controller is going to be a problem.
Old 02-26-17, 08:14 AM
Received 2,804 Votes on 2,539 Posts
I'm completely lost...... two hoists from one control. How would that work out.
Biggest problem is the first hoist uses what looks like a start/run capacitor while the second one uses a start only capacitor.
Old 02-26-17, 08:33 AM
P
You'd be better off with a dual pulley system using one hoist. I'm not sure the hoist would stay in sync even if you could get them to work off one control. As Pjmax said the caps are different and those would need to be relocated to the motor of each hoist and wire a proper size control wire and switch to handle the combined load of the two motors.
Old 02-26-17, 08:53 AM
GregH's Avatar
Super Moderator
Received 61 Votes on 57 Posts
Thumbs up Welcome to our forums!
There is not enough info to be able to help you.
We would need to know exactly which winches you have and if the switches directly operate the winch motors or do they operate a relay which then powers up the winches.
If the switches in the handset directly power the winch motor by connecting two motors you will exceed the capacity of the switch and burn it out.
Besides this for all the trouble you will go through to make this work you will not be able to synchronize the lifting of the two ends.
Old 02-27-17, 01:49 AM
P
thanks guys, ņot the answers I was hoping for but answered nonetheless!
P
