15 Amp receptacle with back wire for a 12 awg push wire
Old 02-28-17, 07:13 AM
Hey guys,
I'm new to the forum, but I'm looking for a receptacle that will take a 12 gauge wire in the back push in part. I don't want the spring tension type, I want it to be when you tighten the screw on the side it'll tighten against the wire. It will also have to be tamper resistant to meet local code. I'm wiring a new construction house for myself and trying to avoid having to curl every wire around the screws if possible. Thanks for any help!
Andrew
Old 02-28-17, 07:48 AM
pcboss's Avatar
Received 39 Votes on 34 Posts
What you are looking for is called a back wired device. The back stab uses the spring tension and are limited to a #14.
Old 02-28-17, 08:43 AM
pugsl's Avatar
Received 29 Votes on 27 Posts
Only outlets that I know of like that are GFCI. Takes about 1 second to loop wire.
Old 02-28-17, 08:49 AM
Received 1 Vote on 1 Post
I have installed a ton of arrow hart (cooper) 6252W-BU. That is a white decora style, tamper resistant, 15 amp receptacle with back wire clamps. They are of course available in other colors and standard style (non-decora). Other manufacturers have equivalent products. You will likely have to buy them from an electrical distributor (local or online) because the big box stores usually don't carry them as the models with back wire are generally commercial grade. And they are quite a bit more expensive than residential grade with side wire and push in connections. But they are worth it IMO.
Old 02-28-17, 09:25 AM
Received 7 Votes on 7 Posts
Back Wired Recptacle
Search Lowes item "61241". No interest other than customer.
Old 02-28-17, 10:58 AM
According to the lowes listing...those are not tamper resistant.
Old 02-28-17, 03:27 PM
Received 16 Votes on 14 Posts
All of the box stores I've seen stock the back wired/clamp style. You just have to look past the 79 specials. Back wire witches are sometimes difficult to find.
Old 02-28-17, 09:49 PM
Thanks for the replys... I have cyst on my wrist and it makes difficult to curl them all but after talking to some local electricians I plan to go ahead and do it. They all said they've had bad luck with them. I figured with the clamp style there wouldn't be anyway for the wire to move, but I guess I'm wrong. Lol thanks again huys!
Old 02-28-17, 10:10 PM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
You aren't wrong. The electricians probably don't like them cause they take longer than the stab back. I don't know ANYONE who doesn't like the clamp style just fine...except for the price.
Old 02-28-17, 10:26 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Not mentioned, side wired with clamp plate.
Old 03-01-17, 04:58 AM
Where can you find the side wire with the clamp plate?
Old 03-01-17, 05:26 AM
ray2047's Avatar
I don't know. Maybe one of the pros does. You could always taske the picture to an electric supply store or hardware store.
Old 03-01-17, 12:48 PM
CasualJoe's Avatar
Received 43 Votes on 35 Posts
Nearly all commercial grade duplex receptacles fit the bill. The catalog numbers that start with "BR" are the commercial devices, here is a tamper resistant one.
https://www.lowes.com/pd/Hubbell-15-...utlet/50183843
It's hard to tell from the picture, but in the description is states, "Internal clamp type back wire feature for a faster secure termination".
