Tandem breakers needed for GE panel?
Received 0 Votes
Hello. I am running a new line to my garage and need some tandem breakers since my main panel is currently full. I believe it is a GE panel and will attach pictures of it and the breakers currently in there. In all of my searching online I can't find any GE tandem 15 amp breakers. Can someone please help me find the correct ones I need?
That's an old crouse hinds panel. They were bought by murray, then murray was bought by Siemens. Should be able to use a Murray branded tandem breaker MH-T, but verify on the label on the door. Can't quite read it from your photograph. You can only install tandems in the 2 lower slots on each side, per the drawing on the label.
Received 0 Votes
I'm attaching and image of my whole panel and (hopefully a clearer image of the label.
Note that I have two 220V breakers in the bottom. I need to use two tandem breakers to free up two spots to send a 220v line to the garage. What is the best way to go about that? Can i do this base on the current configuration?
(It is not letting me rotate the images so they are upright for some reason)
In this paragraph it list compatible type MP breakers. You cannot post text here as the board compresses it to the point where it's not readable.
Received 0 Votes
This link should take you to a very clear image of the panel label
http://i48.photobucket.com/albums/f2...8/IMG_2019.jpg
One way to do it is to move four single circuits...... 10, 12, 14, 16 ..... down to two tandems in the 18-20 locations.
Move 2P breaker up from 18-20 up to 14-16 location.
Put new 2P breaker in 10-12 location.
Received 0 Votes
The label says that MH breakers can be used. Does that mean that I can use the MH-T?
Murray 15 Amp Tandem Single-Pole Type MH-T Circuit Breaker MP1515U at The Home Depot - Mobile
Would I need a circuit limiting or non circuit limiting breaker?
I found the UL document saying that you can use the current Murray MH-T tandems in your panel.
http://w3.usa.siemens.com/powerdistr...urray-MH-T.pdf
