Convert from switched outlet to switched fixture
Old 03-12-17, 11:33 AM
T
Hello,
I have a switch-controlled outlet that has three cables coming into it. I created a diagram below as best as I can. The switch (not pictured) is single-pole with a black on top and a white on bottom position. There is no ceiling fixture and we would like to add one. How can I change this to a standard (non-switched) outlet and make the switch control the ceiling fixture?
Much thanks in advance,
Tom
Old 03-12-17, 11:47 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
So you have a switch loop.
  • At the switch disconnect the 2-conductor cable from the switch.
  • Run a cable from the new light to the switch box.
  • At the switch box connect the whites to each other and the blacks to the switch.
  • (Simplest way of two) At he receptacle if the tab on the brass side of the receptacle is broken replace the receptacle.
  • At the receptacle connect all blacks to a pigtail.
  • At the receptacle connect all whites to a pigtail.
  • At the receptacle connect the pigtails to the new receptacle with tab not broken.
  • Connect grounds per code.
Old 05-02-17, 11:02 AM
T
Thanks ray2047! I was able to install ceiling fans in 2 of 3 rooms but not the 3rd -- I lose access to the cable coming from the outlet to the switch due to the placement of A/C return so i can't fish a cable down to the outlet box. Is there a way to cut that cable where i can access it and add a junction box? I wonder if the following would work:
- cut the cable
- put junction box at cut and put cut cable ends to box
- run 2-conductor cable from box to fixture
- connect black from switch box to black from receptacle
- connect white from switch box to black from fixture
- connect white from fixture to white from receptacle
- connect grounds in new box
- at receptacle connect whites together with pigtail to go to the receptacle
- at receptacle connect blacks together with pigtail to go to the receptacle
Old 05-02-17, 11:28 AM
ray2047's Avatar
Normally not enough slack in the cable you cut to splice so you would need two junction boxes about a foot apart with a short cable between.
Old 05-02-17, 11:33 AM
T
thanks again! Other than the 2nd box does this sound right? As far as the proper connections, that is.
Old 05-02-17, 11:36 AM
ray2047's Avatar
If you have a switch loop and it as previously described yes.
