Need help with outlets
Received 0 Votes
In my kitchen I have some issues with my outlets. I plugged in a laptop to charge in a non-GFi outlet (outlet w/o test/reset?). Doing this immediately popped the gfi outlet to the left (red light came on). I can't push it in. Every outlet between the two do not work. IVe checked the fuse box in garage and everything seems to be ok. I flipped the two kitchen fuses off then on, but still nothing. Any ideas? Would love to not have to call an electrician if I can DYI. THANKS!
Did you unplug your laptop before you pushed the reset? Usually a reset and test button did you push the right button? May have to open last outlet and take a picture of wires so we can see whats there.
Received 0 Votes
Sorry, I meant breaker. Yes, unplugged laptop immediately as outlet didn't work. I will try to upload a picture shortly. Visualize from left to right. Gfi outlet - regular outlet - regular outlet. Problem started when plugging laptop in right regular outlet. Caused gfi outlet to pop and middle and right regular outlets to not work. Guessing all on same circuit?
