Proper Splice
Old 04-02-17, 09:13 PM
I
Proper Splice
Just got done splicing in two circuits (its permitted and the load calcs check out). Anyway, I'm nervous about the splice and wanted to ask if there should be loose wire entering either side of the junction box or is it ok to have the lines taut?
The lines inside are twisted together, wire nutted, and taped.
Also, when I say taut I mean there wasn't much slack and when I added the staple it essentially removed any wiggle room.
Old 04-02-17, 09:30 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Tape is not needed if it is done correctly. Each wire in the box should be 6"-8" long. If the box is metal the ground needs to be pigtailed to it.
Old 04-02-17, 09:47 PM
Received 1,342 Votes on 1,240 Posts
Are you describing the wires themselves entering the box with no outer sheathing ?
Old 04-02-17, 11:28 PM
pcboss's Avatar
Received 105 Votes on 91 Posts
What did the splice look like ? It sounds like the conductors were too short.
Old 04-03-17, 04:43 AM
I
Spliced wires would barely be 6 inches if that probably 4 to 6 in a 4 by 4 box. They twisted together, it was effortless adding the wire nut and i was still able to bend black to a corner white to another, the tape was only added as an afterthought (Ive read it wasnt needed, but it doesn't hurt either). Anyway it sounds as though I need to do two other splices to give slack to these.
Old 04-03-17, 07:52 AM
W
Received 22 Votes on 21 Posts
Cable
The OP is concerned about the lack of slack in the cable outside the box after installing a staple for support.
Old 04-03-17, 10:27 AM
I
Received 44 Votes on 42 Posts
There does not need to be any slack outside the box. Just enough to staple/secure it.
Old 04-03-17, 02:42 PM
ray2047's Avatar
I've read it [tape] wasn't needed, but it doesn't hurt either
Tape sometimes deteriorates with heat and time. The next person to deal with that splice may be cussing you out because of the sticky hard to deal with mess.
Old 04-04-17, 09:07 PM
CasualJoe's Avatar
Received 97 Votes on 87 Posts
How did you splice the ground? Did you ground the metal box?
