No shut off between main breaker box and transformer
So i live in an old house and the breaker box outside is oooold and basicly just exposed to the elements... It also has another box connected to it inside the house.It use to be a duck hunting shack that the new owners added bedrooms and a bathroom too.Well the wires to the inside box are jamed into the same wires that are powering the main box outside.Outside box has no main shut up and is connected directly to the transformer.Unfortunately i had no clue and opened the main box's metal panel directly into the wires coming from the transformer and instantly melted that panel and made the most god awful electrical sound i never wanna hear again.My question is who's fault is this,should i contact my landlord or electical company?
Welcome to the forums.
Sounds like a mess and some real code violations.
You are renting..... you notify the landlord. They hire the electrician.
We couldn't comment much further without pictures. http://www.doityourself.com/forum/el...-pictures.html
If this is a rental, it doesn't sound like it's fit for occupancy. If you call the landlord, he may fix it and try to charge you. If you call an electrical company, they probably won't repair it without bringing all the bad work up to code....$$$$$. And you should never have repairs done to a place without something in writing from the landlord. If you call the local authority having jurisdiction, they may tag the house and you won't have a place to live.
I'd call the landlord first. And look for a new place to live. Sounds like a fire waiting to happen.
Yer lucky you weren't injured or worse. He should consider himself lucky you weren't or he could be liable for....$$$$$$$$$.
The power company is only responsible up the the line side of the meter. Anything on the load side is on the owner.
