Reload this Page >
Switch with loose white(neu) wire in box. what to do with it?
Old 04-11-17, 12:56 PM
B
I have a switch which controls an outlet on the other side of the room.Ther is also a outlet that is fed power from this switch.
A 12/3 wire feeds the switch, red at top of switch,black on bottom of switch,and thie white used to tie into the outlet that is being removed.
The loose wires are the disconnected outlet. The nutted white wire is the one I'm wondering what to do with. It is the 12/3 run wire.
The outlet that feeds the switch has red wire on top on with black under it on hot side. white on the left. but it runs to the switch box but does'nt connect to anything.
What do I do?
Old 04-11-17, 06:26 PM
Received 1,178 Votes on 1,092 Posts
Welcome to the forums.
Not 100% sure what you are trying to do.
Based on what I see and what you've said..... the three wire cable comes from the switched receptacle and the two wire cable goes to the always live receptacle.
That means the two black wires should be combined and then a tail connected to one switch terminal.
The red wire should go to the other switch terminal.
The two whites should be combined.
Old 04-11-17, 06:30 PM
Geochurchi's Avatar
Received 78 Votes on 73 Posts
If everything is working you can put a wirenut on the white and tuck it back in the box,also you could remove the pigtail on that switch and just connect the black to the switch,it also sounds like you have a red and black under one screw on a receptacle, best to install a pigtail there you that you only have one conductor under a screw.
Geo
