New dimmer switch not working
Old 04-13-17, 09:07 PM
C
I just got a new Decora smart dimmer switch (the one that connects to wifi) that I want to use on my recessed living room lighting. After replacing the dimmer switch, only one of the lights is lit (but very faintly and also flickering). None of the other lights will light up. The old switch was 600W max and so is the new one. I'm using compatible LED dimmable bulbs. I reverted back to the old switch and everything works fine again. Does anyone have any clue what the problem might be with the new dimmer?
Thanks in advance!
Old 04-13-17, 09:11 PM
Received 824 Votes on 774 Posts
Welcome to the forums.
Can you post the model number for that dimmer ?
Is this a single switch application..... not three way ?
Was the old control a switch or dimmer ?
Old 04-13-17, 09:28 PM
C
The new dimmer switch is Decora Smart with HomeKit Technology 600W Dimmer, DH6HD-1BZ
It is single pole (not three way)
The old switch was also a dimmer and it still works fine. Just the new one has this problem.
Thanks for your help.
Old 04-13-17, 09:43 PM
The new dimmer requires a neutral connection.
So that would be a three wire connection for you. (ground is not counted)
Did you have a neutral connected ?
It requires the black wire to be connected to hot.
It requires the red wire to be connected to the load/lights.
Old 04-14-17, 10:06 AM
C
Pete: Thank you, thank you, thank you. The old switch did not have a neutral wire, so I was just using the two old wires from that. I ran over to Home Depot this morning and picked up some electrical wire and pig tailed into the neutral wire that was already running through the box. I connected that back to the switch and now it works perfectly.
Thank you again!!!!
Old 04-14-17, 10:08 AM
You're welcome.... good job.
