Coach light & outdoor GFI receptical..
Old 04-15-17, 12:26 PM
NorPlan1's Avatar
Have a Coach Light off the Patio Door to the Backdeck, the Light also has a GFI Outdoor Plug Receptical.. There is only One Switch Inside by the P/D , turning the Light Switch ON tells us there is power to the GFI Plugs.. Unfortunately the Electrical Panel has No Index or Numbered Ledger telling us what each Breaker covers .. Started out the day fine but noticed at one point Light was out and there was No Power to the Plugs.. There is No, 3Wire, just 1 , 14-2 wire in the Junction Box the Coach Light / GFI Plug is wired into .. Could the GFI Plug have Blown ?? Would that have Disabled the Coach Light as well ?? Help Appreciated.. Cheers Thanks..
Old 04-15-17, 12:30 PM
Received 2,954 Votes on 2,665 Posts
Welcome to the forums.
The GFI receptacle would have a test and reset button on it.
Have you tried a reset.... with the light switch on ?
Old 04-15-17, 03:59 PM
NorPlan1's Avatar
@ Pjmax... Yep, Pressed the Test & ReSet Buttons a couple times.. The little indicator light doesn't come on..
Old 04-15-17, 05:32 PM
ray2047's Avatar
Received 15 Votes on 13 Posts
If there is no power it won't reset. Tripped breakers are not always obvious.
Reset all the 15a and 20a single pole breakers by turning them all the way off then on. Test the receptacle to see if it will reset after resetting each breaker.
Old 04-16-17, 03:54 PM
NorPlan1's Avatar
ReSet all 15a 20a Single Pole Breakers
Yes Sir Flipped all Single Pole Breakers, They all Clicked Off / On Firmly.. Tried the GFI Plug Indicator Light doesn't shine..
Old 04-16-17, 04:17 PM
ray2047's Avatar
Time to open the GFCI and look for loose wires. If none check for voltage on the line side wires using a multimeter (neon test light or solenoid voltage tester). You can not use a non contact tester.
