110 to 120 or 220 to 240 When did standard change
Old 04-16-17, 04:42 PM
pugsl's Avatar
Received 59 Votes on 55 Posts
Reading a book where he keeps saying 220 for 240 and drives me nuts. Want to write author to tell him but wondering when standard changed. I guess about 30 to 40 years ago.
Old 04-16-17, 05:09 PM
Handyone's Avatar
For me I have to stop and think not to call 240 220 when I post.
I grew up in Ohio and 220 was what it was called so I just stuck with it.
Old 04-16-17, 05:22 PM
T
120/240V was standardized in 1977 by ANSI C84.1 (NEC tables were updated in the 1984 cycle to reflect this). Most likely the book was first published before that time (as were most books on electrical basics). Prior to this, it had been 115/230 since the 1930's - although it was still very commonly referred to as 110/220.
Honestly its a waste of time to send the author a letter nitpicking something as dumb as that.
Old 04-16-17, 06:59 PM
A
Received 31 Votes on 27 Posts
Think of it like listening to someone with an accent. You understand what they are saying but would never say it that way yourself.
I was taught 117 so was confused for a long time.
Old 04-17-17, 06:01 AM
P
Received 45 Votes on 38 Posts
taz420
You were doing good until you ended with that comment.
Old 04-17-17, 08:40 AM
pcboss's Avatar
Received 69 Votes on 59 Posts
I feel if you are going to write a book it should contain the correct information and nomenclature. No different than posting here.
Old 04-17-17, 08:56 AM
I
Received 42 Votes on 40 Posts
I agree, especially in a technical field. Imagine if the book had joist span tables or nailing schedules from 40+ years ago presented as modern. At some point it becomes misinformation that is more likely to confuse or cause a mistake.
Old 04-17-17, 12:47 PM
pugsl's Avatar
Guy books a few years old but if he writes something again he will know right terms. Thanks for the info.
Old 04-17-17, 01:02 PM
Handyone's Avatar
Good point. I wouldn't want to be guessing on that or electrical.
Good news is we have you guys here
Old 04-17-17, 01:17 PM
T
Yeah but if you're talking about a book first published in the 70s or 80s it's obviously going to reflect the "correct" nomenclature of that time. I had the old Sunset "Basic House Wiring" published in the 70s and it mentioned 110/220. Was it "correct" then? Not really since at that point the "standard" was 115/230. However 110/220 was within the 5% delivery tolerance of that day, so technically your house COULD have had 110/220 at the service if it was far enough from a transformer. I have not seen the second edition from 1987 so I can't say for sure, but I'd assume it was updated to reflect ANSI C84.1 and NEC1984. And if it wasn't, that would be on the publisher/editor, not the author.
It is dumb. I find it very hard to believe that a book written in 'modern' time would contain that egregious a faux pas. Therefore we are led to believe that it is an older book, therefore any logical human would realize that contacting the author is a pointless waste of time. It's akin to contacting an inspector who approved a 3 wire range/dryer circuit in 1988 and telling him that it is no longer acceptable in 2017.
Old 04-17-17, 02:30 PM
P
taz420, that part of your comment took it to a personal level and added no value to your answer. There was no need to infer that the OP was nitpicking and dumb for considering writing the author.
Old 04-17-17, 03:46 PM
T
He is nitpicking. It's an old book. Refer to inspector analogy. That would be nitpicking and dumb too.
Old 04-18-17, 03:42 AM
pugsl's Avatar
New book copyright 2016. Not a big deal just a pet peeve.
Thanks all Don
