Adding Semi-Permanent Receptacle Using Smoke Alarm Wiring
Old 04-17-17, 10:49 AM
C
Question Adding Semi-Permanent Receptacle Using Smoke Alarm Wiring
I have an idea I wanted to run by the group to make sure I'm going down the right path. We're working on our son's nursery and I want to install a camera in one particular corner of the room as it has line-of-sight to everything.
That corner does have a smoke alarm installed with 12-3 wiring. My thought is that I could tap into that wiring and add a surface mount receptacle right next to it. This way I could add a "semi-permanent" outlet that I can eventually remove fairly cleanly in a couple years when we no longer need the camera.
Thoughts?
Old 04-17-17, 11:03 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
Is the breaker the smoke alarms are on a mix use circuit with other things already on it? If yes then it likely wouldn't be a local code violation in your area.
Old 04-17-17, 11:27 AM
C
Just double-checked and they are on a mixed-use circuit!
Thanks!
Old 04-17-17, 06:19 PM
ray2047's Avatar
Sugest a surface race extension box to a surface race "switch" box with a short piece of surface raceway between.
Size:  6.4 KB Name:  981c838f-594b-4188-85bc-e0917df205ed_1000.jpg
Old 04-17-17, 06:44 PM
pcboss's Avatar
Received 148 Votes on 131 Posts
Seems like a lot of work compared to a plug in camera.
