Ryobi 2200 with McColloch chainsaw
Old 04-19-17, 05:00 PM
Norm201's Avatar
Received 594 Votes on 531 Posts
Do you think I can use this McCulloch chain saw for limited light duty use with this Ryobi generator? I think it might be borderline but usable.
McCulloch Electric Chainsaw
SPECIFICATIONS
Model No. . .MCC3516F
Input . . ..120V~, 60Hz, 13.5 Amp . . . . . .120V~
Peak Horsepower . . . .3.5HP
No Load Speed . . .5500/min
Bar Length . . . 16 (40cm)
Cutting Speed . . .10.5 m/sec . . . . . . . . . . . . . . . .10.5 m/sec
Chain Oil Capacity . . .180ml
Net Weight (Without guide bar and chain) . . .4.2 kg (9.24 Lbs)
Ryobi Ryi2200 generator
PRODUCT SPECIFICATIONS
ENGINE
Engine Type......................... Single Overhead Cam (SOHC)
Spark Plug..........................................................LD A7RTC
Engine Lubricant Volume.......................................13.52 oz.
GENERATOR
Rated Voltage.........................................120 V AC/12 V DC
Rated Amps.............................................15 A AC/7.5 A DC
Rated Running Watts ............................................. 1,800 W
Starting Watts......................................................... 2,200 W
Rated Frequency........................................................ 60 Hz
Old 04-19-17, 05:26 PM
Tolyn Ironhand's Avatar
Received 595 Votes on 511 Posts
IMO - Yes.
Old 04-19-17, 06:41 PM
T
Don't you think you'd be better off just buying a gas chainsaw? It'd certainly be cheaper than an inverter generator..
Old 04-19-17, 07:28 PM
Norm201's Avatar
Yes of course, and that is the plan, but I need this as a temp solution.
I have the chain saw and I have the generator.
Old 04-19-17, 08:45 PM
T
Oh okay, I thought you were buying the generator to run the chainsaw lol! Yeah you should be okay running it then.
Old 04-20-17, 06:00 PM
Let us know if it does work and how well. I am curious to know.
Old 04-21-17, 03:33 AM
Norm201's Avatar
Will do when I get to it.
Old 04-21-17, 11:13 AM
CasualJoe's Avatar
Received 163 Votes on 146 Posts
I also believe that little generator will power the saw, but it'll just about max it out. The saw might be just a little slow on starting till the generator RPMs can pick up.
Old 04-21-17, 01:52 PM
Norm201's Avatar
I hope to try it this weekend.
Old 04-24-17, 03:57 AM
Norm201's Avatar
Folow up
Yesterday tried out the generator - saw combination. Works like a charm. At startup the saw will pull near max amps from gen but will run at normal speed thereafter. Will give it real test latter in the week.
