Fan humming rotary control
Got a ceiling fan with downrod that has a control especially for fans. On full speed it's fine, however as you turn it slower, it produces a loud buzzing, which changes depending on the speed. It's not a dimmer switch but wondering if i need a different type.
Fans aren't made to be controlled by rotary rheostat type controllers. Is the switch fan rated? Can you post a picture of the switch? What speed did you initially set your fan to. It should be set to High.
I'll get up on the ladders later. It's like this
https://www.homedepot.ca/en/home/p.r...000158026.html
The switch is fan rated.
Maybe i need a 3 speed one.
Fan is set to high but it has a pull switch on it as well. It's just too high to reach.
