Damaged HID lighting capacitors
Old 04-26-17, 08:56 AM
E
We're replacing all the lighting capacitors in our facility. The lights are 1000W Metal Halide fixtures. We purchased 30 capacitors and after inspection I found that 7 are dented, some worse than others. The seller claims that this isn't a problem, but I'm concerned that the electrodes could be shorted and therefore compromised. Here is a picture, should I be concerned and insist on replacements or use these? Thanks
Old 04-26-17, 10:06 AM
P
Received 1,511 Votes on 1,358 Posts
Dented certainly is not a good sign. I would test them before installing.
Old 04-26-17, 12:50 PM
Received 2,797 Votes on 2,533 Posts
I wouldn't even use the dented caps. They could check good now and fail shortly.
Old 04-26-17, 02:05 PM
T
Received 68 Votes on 64 Posts
Why would you replace with used caps? Your investment in OH labor should demand a low risk part goes in.
Old 04-26-17, 02:34 PM
E
They're not used, they're brand new, that's why I'm questioning the supplier who is telling me they are fine and doesn't want to replace them. I'm looking for other opinions before we go to the effort of using them and potentially have them fail quickly.
Old 04-26-17, 10:50 PM
O
They certainly don't look new. They look like they're salvaged. And given that they're made in China, I'd be very dubious about them.
Best regards,
Brian
Old 04-27-17, 02:31 AM
ray2047's Avatar
Received 15 Votes on 13 Posts
Bottom line the supplier who you buy from has the responsibility to sell you merchandise in good condition. If he doesn't you have the right to replacement or refund. He can if he wants the complain to his supplier but that is beside the point here. Your supplier needs to replace them. If you paid by credit card and he refuses you can dispute payment.
