Disposal works but nothing else
Old 05-09-17, 06:18 PM
D
I have an outlet under the sink that the garbage disposal is plugged into. It works fine. I bought a pump for bottled water and plunged it into the same outlet. It doesn't work. I took off the outlet cover so I could reach the wires with a multimeter and I can't get a reading. I replaced the outlet with a new one and garbage disposal works but nothing else. I should have 120 volts between the black wire and the white wire. Can anybody help?
Old 05-09-17, 06:35 PM
T
The garbage disposal is on a switch.....
Old 05-09-17, 07:03 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You will need to convert the receptacle to half switched. Tell us all the wiring at the receptacle.
Old 05-09-17, 07:31 PM
D
Yes. very good. no power to the outlet because it is on a switch. Thank you Guys!! I can put one half of the outlet on the switch and the other to power.
Old 05-09-17, 08:04 PM
T
Is there only one pair of black and white wires in the box? If there is it means power goes to the switch first, and will require running a new 12/3 cable between the switch box and receptacle box.
If there are more than two wires in the box (plus ground), then it should be possible to convert it to a half-switched.
Old 05-09-17, 08:48 PM
D
Total success. It was the switch box had power so I was able to wire nut to the power on half the outlet and leave the other half on the switch. Its all working!! thank you guys so much!!
