Help to wire this AC motor
Old 05-14-17, 06:32 AM
I can't seem to find a wiring diagram for this 120v fan motor. I want to install a regular plug to plug it in. There is a orange wire that is not connected to anything (hard to see in pics).
Last edited by Jeff9377; 05-14-17 at 08:01 AM. Reason: Add Name plate image. separate others.
Old 05-14-17, 12:58 PM
Received 1,523 Votes on 1,406 Posts
Welcome to the forums.
French built motor.... no technical info found.
That is a two speed motor.
Connect your power wires to the two posts.
Here's my guess based on the label.
Removing the red wire and replacing it with orange will yield the slow speed.
Old 05-15-17, 09:58 AM
Thanks Pete. My only issue is which terminal is common and hot. I'm going to visit a "motor repair" shop and see if they are willing to help.
Old 05-15-17, 11:02 AM
Since it's an AC motor.... there is no polarity. You can connect either way.
Old 05-15-17, 11:34 AM
I did not know that. Thanks. I think your right about the orange wire being slow speed however I don't see a capacitor on this motor. The pic below is the closest diagram I found to date. Hopefully I get to try it out Tuesday. Let you know how it goes.
Old 05-15-17, 12:12 PM
I'm pretty sure I can see the edge of a centrifugal start switch.
Old 05-16-17, 12:48 PM
Solved. The cover had some cork on it. Underneath the cork I found this. Thanks again for the help!!!Name:  IMG_20170516_154602.jpg
Old 05-16-17, 12:53 PM
Good deal finding the diagram. Took the guess work out of the equation.
