Reload this Page >
My refrigerator electric cord barely reaches the wall plug
Old 05-15-17, 06:40 PM
F
The way the walls are built around where my refrigerator is located, the refrigerator has to be pushed in and then plugged up, because otherwise you just couldn't reach it. The receptacle is located on the wall at the top of the rear corner of the refrigerator so You can plug it up after the refrigerator is pushed into the slot. This is an old house from the 1950's and has all the original wiring, so it wouldn't pass code today, BUT, is the way mine is wired dangerous? I could instaul a junction box in the attic above the refrigerator and run another wire for a new receptacle where it would be very low on the wall, to whatever code is, so I could pull the refrigerator out for mantinace or whatever. What should I do if anything?
Thanks
Old 05-15-17, 07:17 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Thread moved to Electrical forum.
Is your existing wiring grounded? I'm guessing no so you might consider a new circuit from the breaker panel.
Old 05-17-17, 12:45 PM
Z
Received 199 Votes on 178 Posts
Can you push the fridge in then plug it in? If so, that sounds like the easiest solution. Though I know you're supposed to vacuum the coils yearly, I have to admit, I don't remember the last time I pulled the fridge out.
If you do want/need to move the receptacle, I'd go with Ray's advice and probably run a new circuit. It will be grounded, up to code, and probably reduce any overloading/tripping you have in the kitchen now. Older kitchens usually had only one circuit for everything, which is woefully limited in today's kitchens.
Old 05-19-17, 06:17 PM
CasualJoe's Avatar
Received 111 Votes on 98 Posts
I don't see the problem. I don't believe I have ever seen a refrigerator that could be pulled out for maintenance without it first being unplugged. I wouldn't do anything.
