Help with a GFCI outlet
Old 05-19-17, 08:56 AM
T
We had 1.4" of rain yesterday, driven by 50mph winds.
A couple hours later my GFCI started tripping. It is inside, but goes to outside outlets. Presumably some moisture got in. It would reset for a while and then trip again. It has been three hours since the last trip, so I think I am out of the woods.
1) Can I just ignore the issue and trust it has dried out, or must I pull all the outdoor outlets and dry them?
2) This is the only time it has happened in the 5 years we have been here (also the only time I have seen a storm like this), but my wife uses the outdoor outlets for Christmas lights. They occasionally get wet and trip the GFCI. It is a pain because my computer is on the same circuit.
I would like to move the GFCI after the computer, but it is a unfinished basement and code requires a GFCI.
Can I leave the first GFCI and install a second one on the first outside outlet (or even backwards on the computer outlet, which is the last before it goes outside)?
Would a fault in the outdoor lighting trip the new GFCI and leave the old one alone? I suppose some are more sensitive than others, but I could swap them if that is the case.
Thanks.
I realize running a new circuit for just the outside outlets is the optimal solution, but I have run wires in outside walls before and can't face doing it again.
Old 05-19-17, 09:06 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes, if you come off the line side not load side of the basement receptacle.
Received 97 Votes on 85 Posts
Why not put the outside receptacles inside bubble covers and keep them dry in the first place?
Old 05-19-17, 09:27 AM
T
They are in waterproof outlet covers, but with horizontal rain nothing is really waterproof. As I said, this is the first time in 5 years it has happened.
For all I know the water penetrated the siding and dripped down.
Old 05-19-17, 09:38 AM
ray2047's Avatar
But which kind, flap or bubble? Yes, first time in five years but gaskets do deteriorate and may need replacing.
As you suggested putting a GFCI outside on the first outside receptacle will prevent loss of basement power. You just need to come off the line side of the GFCI receptacle in the basement.
Old 05-19-17, 09:49 AM
T
So if I reverse the inside GFCI it will protect that outlet, but not pass it on? Then I can install a new out outside. That is a solution!
Old 05-19-17, 09:57 AM
T
This is the outlet cover. They are 10 years old; the gaskets look good.Name:  outlet.jpg
Old 05-19-17, 10:26 AM
pcboss's Avatar
Received 105 Votes on 91 Posts
That cover is for a horizontal receptacle .
Weatherproof in use covers have been required for years.
Old 05-19-17, 11:01 AM
T
Old 05-19-17, 01:18 PM
ray2047's Avatar
Best would be a buble cover (in-use cover) especially if use for Christmas lights.
