No Power to Outlets in Office and Master Bedroom
Old 05-29-17, 05:44 PM
Hello all. This is my first post here, I'm at my wits end and need some help!
The other night all power to the outlets in my bedroom and office was lost. My gf was steam cleaning at the time but was on a different circuit so may not be relevant.
I checked the breaker and it was not tripped but i firmly turned it off and on. This did nothing so to be sure i turned off all breakers and all back on to no avail.
I then thought maybe a bad breaker so I removed the panel cover and grabbed my multimeter. Now the suspect breakers are two boxes with 4 switches. The outside two are bridged together with a metal clamp and the inside two are as well.
I get 120vac out of all breakers the only anomaly is on the 4 switches mentioned above the bottom two wires do not reference the same ground as the rest and only read voltage if referenced to a single screw inside the panel. Not sure if that has relevance, I hope I explained it properly.
I then thought maybe a bad outlet, however it would have to be first in the chain for all outlets to be out. I started with the one closest to panel and noticed they are wired using the push in termination rather than the screw which I've heard can cause intermittent problems.
Anyways I've replaced all 8 outlets and still no power. What have I missed? Is that ground descrepancy something to look at? Any help is much appreciated! Thanks.
Old 05-29-17, 06:05 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Nothing magic in regular receptacles to go bad so usually not the problem. However it often fixes a loose connection. You did use the screws not the back stabs when you replaced the receptacles didn't you? Did you try resetting all the GFCis in and outside the house including ones hidden and forgotten behind furniture?
http://www.doityourself.com/forum/el...ther-info.html
Old 05-29-17, 06:06 PM
Received 1,335 Votes on 1,234 Posts
Welcome to the forums.
No.... your description of your testing results isn't clear.
Can you take and post a picture for us ? http://www.doityourself.com/forum/el...-pictures.html
Old 05-29-17, 08:35 PM
Yes I replaced the receptacles with screw terminations.
I haven't tried resetting all the GFCIs because there are none in the two rooms that are having problems. Could they still have an effect?
Unable to post pictures at the moment but I'm assuming the unclear part was about the breakers. Will post some when able.
Old 05-29-17, 09:11 PM
G
Received 2 Votes on 2 Posts
A GFCI could be several rooms away, but on the same circuit. Check them all.
A former mod here always suggested mapping your circuits for easier trouble shooting in the future.
I did it for my former home and for this one. Saves a bunch of guessing.
Old 05-30-17, 07:14 AM
P
Received 125 Votes on 99 Posts
Did you check for voltage at the first outlet in the circuit? If there was no voltage at the first outlet, changing the other seven down stream isn't go to correct the problem.
Old 05-30-17, 09:19 AM
ray2047's Avatar
Notes: You can NOT use a non contact tester to determine if you have voltage at the receptacle. Voltage needs to be checked at the wires.
Old 06-25-17, 10:30 AM
B
Thumbs up Hidden GFCI
Thank you so much for the information on this thread. I power washed my back patio yesterday and then my porch light and plug ins on one side of my bathroom would not work. I checked the circuit breakers and none were in the off position. I tried resetting all the circuits including the main one. Still did not work. Read this thread and went on search of a GFCI. There was one in the garage. I pressed the button and it turned green. Went back to my bathroom and the plug ins were working! Still have to wait till tonight to make sure the light automatically comes in when it turns dark. I am a 63 year old widow ~ this gave me such a sense of accomplishment to figure this out!!!!
