How do I clean an electrical socket?
Received 0 Votes
One electrical socket I use often has some black dirt in and around the openings. I'm guessing it's dust that got fried over many years. After shutting off the power, of course, how do I clean the socket--inside the openings?
Clean it with a Q-tip and alcohol.
It's more than likely carbon from the arc that is caused by connecting a device that uses power as soon as it's plugged in.
It may be time to consider a replacement.
Replacement is a much better option. If it is that old the contacts inside might be getting loose and making poor contact which would lead to heat buildup and arcing.
