4-Way ZWave GE Switch Wiring Frustration
Old 05-30-17, 06:33 PM
B
I'm having some trouble with a 4-way circuit, a GE Zwave switch which uses a white neutral and just traveler wires, no load/hot.
I have the main hot location and the other 3-way location licked, it's the 4-way switchbox giving me headaches.
I tried the two red wires to the GE switch in the 4-way circuit and capping the black together to no avail, I assumed that would be the way. I must be wrong. No light at all when I do this.
I previously had a dimmer switch at the hot location in this 4-way circuit so it's possible that load and traveler got mixed up, so any tips identifying those would help. The hot wire was of course easy to identify in this location.
All details are below.
Box 2 is the real problem though I may have the load and traveler swapped in Box 1 though I've moved them around as well. I have a multimeter (don't think I have a long enough jumper wire though) so any suggestions on testing I can do by flipping switches and taking measurements on bare wires to help identify wires in Box 1 or Box 2 would be great.
Pretty sure Box 3 is correct, Box 1 I might have load and traveler swapped, if that even matters, and Box 4 I am now stumped on the 2 black/red pairs and if the red are travelers, the black or travelers, or what. I can say that one of the blacks is definitely throwing 120 volts regardless of the master switch's position (though I have not disconnected the hot/master switch yet, but maybe that tells us something too.
**Box 1 (Hot)**
Pics:
Old Box 1 - Lutron Dimmer
New Box 1 - GE Zwave Dimmer
- White = hot wire
- Red = Load or Traveler (may need to swap?)
- Black = Load or Traveler (may need to swap?)
- Green Ground
- White Neutral jumper
**Box 2 (4-Way Circuit)**
Pics:
Old Box 2 - Standard Toggle
New Box 2 - GE Zwave ADDON
PAIR 1
- Red = Load or Traveler?
- Black = Load or Traveler?
PAIR 2
- Green Ground
I assume there is no hot in this box???
**Box 3 (3-Way)**
New Box 3 - GE Zwave ADDON
- Red = Traveler
- Black = Load (Capped)
- Green ground
- White neutral jumper
99% sure I have this box wired right.
Note with Box 1 and 3 connected as displayed, and Box 2 connected with the old toggle switch in the ON position, Box 1 and 3 function perfectly.
Old 05-30-17, 08:40 PM
C
Received 2 Votes on 2 Posts
Here's a link that may help you. Scroll down to the 4 way diagram.
http://homeseer.com/pdfs/GE_Jasco/45...al-English.pdf
Old 05-30-17, 09:23 PM
Received 1,321 Votes on 1,221 Posts
Are you using one master and two slave controls ?
Which switch does the hot come in ?
Which switch is where the load is ?
Normally you would pull out the four way switch and connect all like colors together.
White to white, red to red and black to black.
One of those wires is the traveler.
One is the neutral.
One can be used for the load.
When I install a Z system.... I make the white neutral, the red the traveler and the black the remote load.
Old 05-30-17, 10:21 PM
B
Thanks folks.
The links were helpful, I realized I was connecting the neutral to the wrong white bundle in the 4-way box. There was a live hot bundle in there next to the neutral bundle (both bundled white wires, my mistake). Switching to the proper neutral bundle solved my problem.
The key was indeed to wire nut the black travelers together eventually to the load, and use the reds as the travelers connected to the switches for the GE switches.
Old 05-31-17, 02:06 AM
Good job. It can be very confusing.
