Reload this Page >
OK to splice 3 grounds together to run thru conduit, then back apart?
Old 06-10-17, 09:32 PM
B
Need to run 3 circuits through 1" PVC conduit... going to use Romex from panel -> junction box, then THHN thru conduit from Jbox to another Jbox in attic, then switch back to romex in that Jbox to run thru attic.
Probably a no-brainer here but I wanted to be 100% positive:
I know you can use a single ground through the conduit for all 3 circuits as long as it's the size of the highest rated wire, but when looking into all that, every example I've found is all THHN all the way back to the panel (as in, one ground all the way back to the bar). Since I'm using multiple romex from the panel to this conduit, do I just connect the grounds from all three Romex to a single ground wire, single ground wire through the conduit, then split it back up once it comes out the other end of the conduit to the individual circuits? Is that fine? 3 to 1 back to 3? (only meaning ground)
edit: bah.. tried to draw it but the html messed up my sketch
I assume no issues but I like to double check when I'm not 100% sure.
Thanks,
Brian
Old 06-10-17, 10:20 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Yes, you can connect all three NM-b grounds to a single THHN/THWN ground. Same for both ends of the conduit.
Old 06-13-17, 02:12 AM
B
Great. Thanks Ray~
12345678910111213141516171819202122232425
Old 06-13-17, 09:36 AM
CasualJoe's Avatar
Received 99 Votes on 89 Posts
Huh?? .....................................
Old 06-15-17, 06:21 PM
pcboss's Avatar
Received 108 Votes on 94 Posts
Probably filler for the 25 character minimum.
Old 06-17-17, 06:26 PM
CasualJoe's Avatar
Ok .......................................
