Reload this Page >
Missing metal tab to join 2 batteries on a battery insert tray.
Old 06-11-17, 02:45 PM
I used aluminium foil to connect them but the batteries seemed to wear out very fast. It's 2 AA batteries.
What the best way to connect the batteries?
Old 06-11-17, 04:25 PM
Received 315 Votes on 289 Posts
You can get a strip of copper or brass and cut it to shape making your own connecting strip. You could also use steel though rusting might eventually be an issue. Thin sheet metal can be salvaged from dead appliances around the house or can be bought from hobby and craft stores.
Old 06-11-17, 05:22 PM
Is aluminium foil high resistance? Is that why the batteries died quickly or just coincidence?
Old 06-12-17, 06:00 AM
Aluminum conducts better than the steel used in the battery holder so it's probably coincidence.
Old 06-12-17, 08:37 AM
Go to a 2nd hand store and find another gadget which uses batteries. Buy it and remove the spring/metal piece from that. These things are cheap at 2nd hand stores.
