Dimmer Switch or Light Control Panel Options
Received 0 Votes
What kind of switches or light control panel should I buy to achieve the goals below? I am sure there are many expensive and sophisticated options. How can I achieve most of these goals with simpler and less expensive options. Nothing has been wired or installed yet.
If you know some good web pages that explain these options, that may be all I need.
Thank you in advance.
- I want to control 3 to 4 sets of kitchen lights from one location (1 chandelier, 2 other ceiling lights, 3 under cabinet lights, 4 sink light which I might just group with 2.)
- I don't want a remote control or the ability to control lights from computer or smart phone, but if I must use a computer or remote to program light scene settings that's fine.
- Under cabinet light will be LED, and the other lights will accept A19 bulbs, and I want to use LED A19 bulbs.
- At least the chandelier and other ceilings lights should have a 3 way switch, but ideally I could at least turn all the lights on/off from the 2nd location even if all dimming was done at the other location.
- Is it possible to set dimming levels for the individual lights sets, but then turn on/off and adjust overall dimming on the whole set at once?
