Underground splice to 14 TWU?
Received 0 Votes
I'm reusing an old well pump and repurposing as a river pump. The pipe needs to go 200' across some land (buried 2') and then connect to a pressure tank in the garage for irrigation only.
The current wire on the pump is 3 wires 14TWU. One red, one black, one white. Where I cutoff the old connection, it's connected to what looks like 12/3 with a ground as well.
What is the yellow wire on the pump? And do I need 12/3 UF to splice to this? I only have 12/2 UF so if I have a long enough piece could I cut a 2nd length and just label one of the wires red.
Received 0 Votes
Can you bury the individual wires without UF jacket?
Received 0 Votes
Isn't submersible well wire the same as UF in terms of strength, ie you can bury UF so can't you bury TWU?
Can I use 2x14/2 lengths of UF to make 3 wires (with a spare not in use) and splice that to the 14/3 TWU?
Not sure what I should label yellow wire as, white presumably?
Having a yellow wire on a well pump usually means the pump needs to be connected to a starting relay box and not directly connected to a power source.
The yellow is normally the run winding but you need to check what your specific pump requires.
What type of pump is this?... make and model ?
Nnormally only a submersible pump is connected with a relay box.
Received 0 Votes
Yeah I have the control box. Goulds submersible pump. But the control box will be in the garage and is 300' from river to garage and I have 200' of old pipe and submersible wire. I need to splice in 100' of probably 14/3 to connect then maybe put the individual submersible wires in conduit.
Or just get a new section of 300' 14/3.
Received 0 Votes
It's not in yet but they're is 200' of existing 14/3 rubbing the pump and has been for 25 years. It was then connected to 12/3 for about 100'.
Assuming the same would work.
Nothing's connected yet so can't measure but the pump needs 240v and 5.6A.
Previous Thread
Next Thread
