Outside junction box height snow/ground water
Old 06-18-17, 06:20 AM
Q
Received 1 Vote on 1 Post
I want to install a utility junction box on a post in the ground outside. It will be a weather proof . Is there a minimum height to protect it from snow?
Also the ground gets soaked in the spring. Is the a minimum depth to bury the post below ground as well (treated wood)?
Old 06-18-17, 09:57 AM
pcboss's Avatar
Received 114 Votes on 99 Posts
The electrical code does not address either issue.
Old 06-18-17, 03:12 PM
Received 104 Votes on 91 Posts
Post needs to be set at least below the frost line.
I'd be using a 6 X 6 so I did not have to deal with the curling, twisting, checking often seen on a 4 X 4.
If it was mine I'd be installing the box about shoulder high.
