Grounding Metal box to Plastic box for outlets
Old 06-26-17, 08:09 PM
Received 1 Vote on 1 Post
Hello Experts,
I have tried couple of things and nothing works so please advise on correctly wiring
1. From Panel I have source going to plastic box. (Ground does not work here). In here ground wire is connected to outlet.
2. On left wall of plastic box is wall with metal box (Ground works here). Ground wire is attached to Box with that green screw.
3. On right wall of plastic box is wall with metal box (ground does not work). Ground wire here is attached to box with that green screw.
How do i fix the problem. Please suggest.
Thanks,
S2K
Old 06-26-17, 08:14 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Fix what. Ground it for safety not function. It only works in case of a fault. It only works where conductive materials are present. A plastic box doesn't conduct.
Old 06-26-17, 08:20 PM
Received 834 Votes on 781 Posts
It doesn't make a difference if it's a plastic box or metal box. If you have a cable going to the plastic box..... with the ground wire going to the receptacle..... and no ground is present.... you've lost it at the other end of the supplying cable.
Old 06-27-17, 12:52 PM
C
The ground wire only bonds the case of what you plug in but most residential home equipment (up right vac, clothes iorn, lamp, ect) only has a 2 prong plug anyway because the body is plastic not metal like a microwave or washing machine so even if the ground wire in a plastic box is (open) meaning doesn't do anything it doesn't matter. It's against code but not a big safety issue and it would only be an issue if you sell your house because a whole house inspection would catch it and make you change to 2 prong receptacle so no big deal.
