Reload this Page >
Can I use a 6/3 wire to hookup a sub panel for 2 x 40 amp double pole breakers
Old 06-28-17, 09:55 AM
I am.replacing a tankless water heater from 13 Kw to 18 and it requires 2 40amp double pole breakers. But I don't want to run another
6/2 wire from the main panel and I was thinking of just putting a sub panel use the 6/3 that is already there and put 2 40amp double pole breakers in the sub panel. Is the 6 gauge wire sufficient to handle this load?
Old 06-28-17, 09:59 AM
Received 521 Votes on 491 Posts
Welcome to the forums.
#6/3 is good for 55A or so max. 2x40A breakers is 80A total.
Old 06-28-17, 10:01 AM
pcboss's Avatar
Received 40 Votes on 35 Posts
Your tankless needs two circuits to feed it. The #6 is way too small.
Old 06-29-17, 06:56 PM
Thanks guys I just got more 8/2 and it should do the job.
