CSST Bonding
Old 06-29-17, 04:13 PM
CSST Bonding
Hi,
I have about 20' of CSST that runs from the main iron gas line to the kitchen stove.
1. Do you think it's necessary to ground?
2. If necessary to ground, can I run a ground wire from point B (see diagram) to a common ground wire inside an electrical switch box?
Thanks!
Old 06-29-17, 06:50 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
You might want to look at this recent thread: http://www.doityourself.com/forum/el...bonding.html#b
Old 06-29-17, 07:28 PM
Received 36 Votes on 34 Posts
Ground wire has to run all the way to the load center (breaker panel)'s ground bus or grounding rod outside.
You cannot ground gas line to ground wire in a switch box.
You will need to use 6 AWG bare copper wire. You can bond to point B or anywhere in iron pipe before it.
It is best to bond at the entrance point.
Old 06-29-17, 09:25 PM
Received 508 Votes on 478 Posts
I agree with that 100% and that is what the inspectors I've dealt with wanted.
However, I used #6 green THWN and had no problems.
Old 06-30-17, 07:32 AM
pcboss's Avatar
Received 39 Votes on 34 Posts
Technical point, it is being bonded not grounded.
