Reload this Page >
3 Light Fixtures on one switch, possible to remove one and replace with fan?
Old 06-30-17, 06:18 AM
I have a bonus room above the garage, it's probably in 25-30' length and 15' wide. There are 3 light fixtures in the ceiling of the room controlled by one switch at the door.
Is it possible to take the last fixture (farthest from switch) out and replace with a ceiling fan/light combo and keep it hot all of the time, so the ceiling fan/light combo operate independently of the switch?
Ideally, I'd like our guests that stay to be able to use a remote to control the fan and light on that side of the room.
Old 06-30-17, 06:29 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Probably not possible unless the lights were wired with 3-conductor cable (black, red, white) which is unlikely or unless they are not daisy chained (one light feeding the next). You could install remotes at all three lights.
Old 07-01-17, 10:37 AM
Ray is right and most likely you will need to run additional wires to the fan location to make it work like you want to.
