110 Outlet
Old 07-11-17, 09:50 AM
T
110 Outlet
No power to two bedroom light sockets not a breaker problem have found a nearby 110 receptacle in a metal box with the tester it lights up only when I touch the positive to the Box itself or to the ground copper wire
Old 07-11-17, 10:13 AM
It could be a lost neutral. Try to find the closest junction box.
Old 07-11-17, 11:18 AM
Received 97 Votes on 85 Posts
A little punctuation in your posts would help us decipher things better as well.
Old 07-11-17, 11:26 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
There is no 110V in the US anymore. All 120V now.
Outlets are often separate from lighting.
Agree, sounds like a neutral may have come loose.
Old 07-11-17, 01:54 PM
pugsl's Avatar
Received 75 Votes on 68 Posts
Pull outlet out from wall and move any back stabbed wires to screws and and redo any wire nut connections. If not there do the same to last working outlet..
Old 07-11-17, 05:14 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
No positive or negative with AC power. What kind of tester. If a non contact tester it is useless for real testing.
Old 07-11-17, 05:15 PM
That's the way it should be. I can't count the times that I found that not to be the case.
Old 07-11-17, 06:51 PM
Gunguy45's Avatar
Super Moderator
Yeah, I was thinking he had said it was a pretty old house often NOT the case then...different thread.
Old 07-12-17, 01:04 PM
T
Thanks everyone! I found the problem. It was a loose neutral.
Old 07-12-17, 04:25 PM
ray2047's Avatar
Good work. Thanks for letting us know.
