What is this steel plate?
Old 07-28-17, 01:21 PM
R
I want to change the faceplate for the coax out. I plan on installing a low voltage gang box but I don't know what this steel plate is. It isn't screwed in, rather sort of jambed between a piece of plywood and the sheetrock. Can I just remove it?
Thanks for any input!
Name:  coax out 01.jpg
Name:  coax out 02.jpg
Old 07-28-17, 01:24 PM
pcboss's Avatar
Received 148 Votes on 131 Posts
That is a flush plaster ring to supply a place to mount the faceplate.
It may be secured to the stud face.
Old 04-25-19, 03:56 AM
Geochurchi's Avatar
Received 154 Votes on 140 Posts
Hi, if that plate is where you want the coax outlet just reuse the ring as long as it’s secure, screw the new plate to it.
Geo
Old 04-25-19, 05:21 AM
Received 441 Votes on 367 Posts
It's a low voltage ring. The holes in it are the same a junction box and any device that mounts in a box will fasten to it.
Old 04-25-19, 02:36 PM
Received 2,951 Votes on 2,663 Posts
You don't need a box for low voltage wiring. That ring will work perfectly.
Old 04-25-19, 02:44 PM
A
Received 72 Votes on 65 Posts
I know it's easy to do because I've inadvertently replied to them too, but this is a two year old thread, and you can't see it now because one of the moderators (I assume) removed the inappropriate or whatever post, and the only reason it popped back up is because some scammer or whatever posted a reply to it last night or this morning.
Old 04-25-19, 04:45 PM
Thanks akaPedro.......................
