Living room outlets not corresponding with light switch?
Old 07-31-17, 12:42 PM
B
Hey gang. My wife and I just moved into our first home this past weekend. It is awesome and scary.
The first thing and only issue I'm having with it is in our living room.
We have 5 outlets in the living room. There are two entry ways to the living room with switches.
The only weird thing is, the switch is only communicating with one outlet.
I've been up all night (and day today) trying to work it out by reading information tutorials and watching videos.
Here is the setup for the switches and outlet:
Only one of the outlets is corresponding with the switch, but they are all set up the same way with the wires.
Help! I've run out of ideas.
Old 07-31-17, 12:51 PM
Received 1,321 Votes on 1,221 Posts
Welcome to the forums.
The wiring looks ok on first view but one of the main problems is that the jumper does not get removed on the neutral (silver screw) side of the receptacle.
Only the jumper on the hot (brass screw) side gets removed.
When installing wiring on the screws.... the loop goes on the screw facing clockwise so that as you tighten the screw... the wire is drawn into the center of the screw.
That white wire is on backwards.
Old 07-31-17, 01:06 PM
B
Hi thank you for the reply!
Maybe I'm just confused. isn't that picture from the silver side? Thus the little tab stays on?
Thanks.
Old 07-31-17, 01:15 PM
Yes... that is the picture of the silver side and yes that jumper should be intact.
Old 07-31-17, 01:25 PM
B
Sorry for the confusion.
But isn't it intact?
Old 07-31-17, 01:34 PM
It looks broken in the picture.
The picture shows the hot/brass side but the bridge is the same on both sides.
(This is not your picture)
Old 07-31-17, 01:37 PM
B
[ATTACH=CONFIG]83693[/ATTACH] I believe that is the brass side without the clip?
[ATTACH=CONFIG]83694[/ATTACH] And that the intact silver side?
Or maybe I just need new outlets lol.
Old 07-31-17, 01:41 PM
I can clearly see the open bridge on the brass side.
I cannot see it 100% clearly on the neutral side.
This is an intact clip..... not cut.
It connects both screws together.
Old 07-31-17, 01:50 PM
B
Here is a better picture (with my ipad plugged into as I'm still testing)
Old 07-31-17, 03:06 PM
That receptacle has the bridge in place and the white wire is on correctly.
That's not the same receptacle you previously posted.... is it ?
