Recommend a breaker
Received 0 Votes
After turning off the main (and wearing my 200Kv rubber gloves) and taking a look inside my panel, I discovered that installing a new breaker seemed simple enough (but I don't know what I don't know). The one thing I do know is that I need to make sure I buy the right circuit breaker to add. I copied down all the info from one of the breakers that was installed at construction time (28 years ago). Can anyone suggest a currently available (i.e., from Amazon or a big box store) breaker that would be compliant?
Electrical Panel: Cutler-Hammer, Issue No. V-1711 (might have other markings, too)
Existing 20A circuit breakers: 1 Pole Unit, Issue No. MG-1750, Class CTL-Type CN, 120/240 V.A.C., AL-CU
Googling for those Issue Numbers wasn't helpful.
Cutler Hammer has two lines of breakers/panels CH and BR. Similar to how Square D has QO and Homeline breakers/panels. CH is Cutler Hammer's better line (more expensive) line of panels/breakers.
What size/type breaker do you need? (Example: single pole 20 amp)
Received 0 Votes
I only need one single pole 20 amp. Unfortunately, that's half of the empty slots, but I don't anticipate needing to add another circuit ever again. The cost of paying someone to upgrade to a 200 amp panel would prevent me from ever needing to.
I suspect the OP posted this...
But meant this...
MG-1750, Class CTL-Type CH, 120/240 V.A.C., AL-CU
But meant this...
Received 0 Votes
Good point, PJmax. That matches the facts. I am working off my notes. I'd have to pull a breaker again to check. The label used 1/32" high letters, which should probably be illegal.
Thanks, everyone, for the help!
