confused
I moved into a house recently. I am renting it. I checked around to see if the outlets were grounded so I could hook up my computer. My surge protector lights up to indicate faulty wiring. I found a few outlets that showed up as grounded. I went and bought a receptacle analyzer and it too showed correct. I opened a few outlets to check what the difference between them was and found nothing. The outlets that show ground only have 2 wires(white and black) connected to the receptacle. Im only starting to learn this stuff and im very confused. Why isnt there a 3rd wire?
I'm not an electrician, but yes, it is possible that only some of the outlets are grounded by this method and others may not be grounded at all.
As you know, a surge protector is useless without a grounded circuit outlet. Make sure that your computer components are connected to grounded outlets only.
Good luck!
Mike
Good luck!
Mike
If the appliance does not have a 3 wire plug, there is no advantage to having a grounded receptacle. The installation of a 3-wire (grounded) receptcale without a ground is a code violation, unless the receptacle is being fed from a GFCI and is tagged "GFCI protected, no equipment ground".
Don(resqcapt19)
Don(resqcapt19)
