Need Help WIth Outlet Tester
Old 08-21-17, 10:42 PM
N
I recently purchased the Sperry Instruments (GFI6302) Receptacle Tester and tested it on a few outlets. I tested it on non-grounded 3 pronged outlets that were used to replace 2 pronged outlets (these outlets are not GFCI.) I know for sure these outlets are not properly grounded however the tester shows that they are wired correctly (and grounded.) How can it be? Am I using the tester incorrectly?
Old 08-21-17, 10:56 PM
ray2047's Avatar
Are they metal boxes with Bx cable?
