Electrical Panel
Electrical Panel
Need some guidance. Installing 7 new circuits for finished basement. Sub panel is Square D Homeline 100amp. Going to hook up the remaining new breakers (6 more to go) to already existing sub panel and I noticed the copper bus only extends up to the first 8 slots. Panel has 12 knockouts and the plastic track extends to those 12 locations as well. Am I missing something here? Is there a bigger copper bus I can install? Let me know options, I am hoping I do not have to replace the entire sub panel. Photo attached.
The cover is used for two different panels . You have space for two more full size breakers. The panel may take tsndems, but if you need afci protection a tandem will not work
The last picture shows an = sign and "two single poles" for all spaces. From that you should be able to fit tandems in all 8 spaces yielding 16 circuits. As mentioned, AFCI beakers need their own space as don't come in a tandem version.
