Cabling for cooktop and single wall oven
Old 09-07-17, 07:06 PM
A
I've got a 50amp cir. breaker and Type NM-B 10-2 w/grnd plastic 600 volts cirtex-u (UL) cable on standby ready to connect hoping these will be ample to handle the following appliances I intend to install later this year.
http://www.sears.com/kenmore-30inch-...p-02249512000P
GE Monogram 30 inch Induction Cooktop
Electrical rating:
7700W at 240V/60Hz
Will this be enough to work on the one circuit?
Old 09-07-17, 07:58 PM
Received 1,189 Votes on 1,100 Posts
Welcome to the forums.
No..... you only have 240v at 30A.
Your GE range requires 7700w @ 240v which is 33 amps.
The wall oven calls for Total Load: 3.4 kW @ 240Vwhich is 15A. That means your existing cable would be good for just the wall oven.
Old 09-08-17, 12:35 PM
A
So, the 50 amp circuit breaker is ample. But I need 8 -2 cable?
Old 09-08-17, 12:44 PM
#10 wire is only rated for 30A and should never be connected to a breaker larger than 30A.
You can put the #10 cable on a 2P20A breaker for the wall oven.
Then use the 2P50 and run new 8-2 w/grd.
When I'm called to run a replacement or new range line.... I use 6-3 w/ground. Some ranges require 120/240v connection which is 4wires. The three wire cable w/g future proofs the run.
Old 09-08-17, 07:39 PM
A
Thanks, Pete. On your advise I purchased a 2p20A cb to use with the 10-2 cable for my oven.
FYI, this is the "future" remodeling project on which I've been working and for which I've been waiting for 23 years. If I live another 20 years another remodel is not in my stars. Whether I sell or gift to charity my home I don't give a d*** what the next owner does or wants. Chances are either would demolish and build 4 homes on the huge lot. So, doing more than is needed now for future possible changes is neither my concern nor reasonable. And, technical info should include the fact that the cable from the cb and load center to the box in the wall behind the lower cab serving the new cooktop will be max 10 ft. They are literally around the corner from each other.
My questions are re the cooktop solution.
1. Is there any safety or similar reason I should not use the 50 amp cb for my cooktop which recommends a 40 amp cb?
2. The ampacity charts seem to imply if I use NM-B cable it would need to be 6 gauge or if I use THW, THWN, SE, USE, XHHDW I could use 8 gauge.
Thanks much.
Old 09-08-17, 08:25 PM
The breaker is ok. My chart says 45A for 8-2 NM-b. If it's a short run.... use the 6-2.
Old 09-08-17, 09:12 PM
A
Huh? Your response assumes I can read your mind. Sorry, I'm not that perceptive.
