250 volt outlets
Old 09-17-17, 09:17 AM
U
250 volt outlets
Hi, I have a 4 prong outlet that I was using for a stove. On the outlet it says 50A 125/250V
I want to plug in an electric motor but the plug is 3 prong. The sticker on the motor says 115/208-230 V. On the plug it says 50A - 250V.
Also, there's a sticker on my breaker box that says 120A. 120/240 VAC/C.A.
I turned the breaker off and took off the old outlet, exposing the 4 wires. I also looked around on YouTube and saw someone installing a 3 pronged outlet. They screwed the grounding wire to the back of the box and simply attached the rest of the wires to the outlet accordingly. But I wanted to ask someone before trying that. Any advice would be greatly appreciated, thanks.
Old 09-17-17, 09:25 AM
H
Received 88 Votes on 78 Posts
You're safer upgrading the cord on the motor to 4 prong NEMA 14-50 (hot, hot, neutral ground), rather than improperly downgrading the outlet to 3 prong NEMA 10-50 (hot, hot, neutral).
Old 09-17-17, 09:26 AM
Received 1,030 Votes on 956 Posts
Welcome to the forums.
Our voltage is 120/240v. The 250v marked on the device is its maximum voltage. You have a dual voltage motor there which needs to be internally changed to high OR low voltage.
The receptacle require two hots and a ground. The neutral will be capped off.
Old 09-20-17, 04:03 PM
U
thanks, I changed the outlet and it worked though I'm not getting the torque I should be getting on my motor. I'm using a 1.5hp motor on a 2x72 bet grinder but it bogs down under medium pressure. when I got the plug installed it was supposed to be set for 230 V. is it possible that he just made a mistake and it's on 115? or could there be another reason? thanks again
Old 09-20-17, 04:29 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
If it was set on 120 it would probably burn up on 240. Is this a used motor? If so what was its original use. A motor for a fan doesn't have much torque. The stated HP on compressor motors are often overly optimistic.
Old 09-26-17, 07:31 AM
U
it came with the belt grinder so it should be new, here's a pic of the sticker that came on it. also sry for late reply
idk why the pic isn't working, but it's a Leeson and the sticker says.
CUST.PN:
DUTY: CONT
INS:F4
TYPE:KF
AMB: 40*C
PH:1
ENCL:TEFC
FR:56H
CODE:J
DESIGN:L
THERMALLY PROTECTED
HZ: 60
HP/KW: 1.5/1.12
RPM: 1725
VOLT: 115/208-230
FLA: 17.2/8.8-8.6
SFA: 19/9.8-9.5
SF: 1.15 EFF: 79 FL PF: 73 (0.73)
COOLING CODE: 41
IP: 54
Let me know if something doesn't make sense and I'll double check. thanks for the help
Old 09-26-17, 10:30 AM
Certain picture hosting sites are blocked from being linked here. You can post your picture directly to the board. http://www.doityourself.com/forum/el...-pictures.html
The motor model/part number is missing.
It's not always the size of the motor. The pulley sizes have a lot to with the operation. What sander did you get ?
Old 09-26-17, 02:40 PM
U
right, I left a few things out at the top:
CAT.NO: 110089.00
DATE: L16B
MODEL: M6K17FB3L
CC:
the belt grinder is a 7x72 KMG PL. In the description on the website it says "3 ideal belt speeds of approx: 900, 1800, and 3600 ft/min." it looks like this
Old 09-26-17, 03:21 PM
I'd imagine it's the faster speed that is bogging down. At the slower speeds it should be unstoppable.
That motor looks more than able to handle that application.
Item # 110089.00, A/C Single Phase Agricultural Duty Motor
Old 09-26-17, 05:16 PM
U
well, I just tried at the slowest speed and yes it's much better for grinding steel. thanks for all the help !
