Weatherproof Outlet Install
Old 09-17-17, 04:07 PM
R
Received 1 Vote on 1 Post
i want to install a weatherproof outlet on the outside of a shed, the shed itself contains a sub-panel inside so power will be coming from there. Not sure what is needed to get the wiring from inside to outside receptacle in terms of conduit, etc. I have some flexible non-metallic 1/2" pvc but unsure how to connect that to the weatherproof box kit I purchased (it has a couple of threaded ports but the conduit fittings appear meant for a knock out). What is typical approach in this scenaro?
Old 09-17-17, 06:01 PM
Received 1,480 Votes on 1,368 Posts
If the receptacle is close to the panel..... just use cable.
The box will have 1/2" threaded hubs. That flex cable should have 1/2" threaded fittings with nuts. Take the nut off and screw the fitting directly into the box. The picture shows one type of flexible conduit.
Old 09-17-17, 06:50 PM
R
Ok great, I was hoping to be able to do something l like that. Thanks PJMax!!
