LED fixture came with no assembly instructions! help!
Old 09-21-17, 01:29 PM
The light comes with a big black wire containing a blue and brown wire. One end presumably connects with the two white wires shown below, while the other end is connected to 2 of the 3 wires I have poking out of the ceiling box (a thick white, thick green and thin brown). I connected the wires in every configuration possible but it doesn't work. I don't know what the function of the white or black loose pieces in the photo and didn't use it anywhere yet. Help!
Old 09-21-17, 03:19 PM
ray2047's Avatar
Those are the colors for UK not canada. Does it say it is for 120v?
Are you confusing cables and cords with wires? A wire is a single conductor. A cable is two or more wires in a sheath. A cord is similar to a cable. Post a picture of the wires in the ceiling box.
I tried to make your picture better but still not sure what I'm looking at. I don't see colors you mentioned. I see a power supply with two white wires coming out.
I would expect to see a black and white house wire in the ceiling box. You didn't mention a black wire. If your house is wired with cabler there would no brown wire. If wired with conduit brown would be very unusual. I'd expect it to just be a leftover wire from the previous fixture that needs to be removed.
Old 09-21-17, 03:46 PM
I'm not particularly fond of the tape job on the ballast/inverter.
If I received a fixture like that I'd send it back.
Old 09-21-17, 04:58 PM
ray2047's Avatar
So it wasn't just me. Almost looke like an amature repair job. Is this used or from Ebay?
Old 09-22-17, 08:28 AM
The black parts look like a cable gland/connector meant to affix the cable to a through-hole (presumably in the light housing) and to provide strain relief and abrasion protection for the cable.
The white part is a wire connector.
Old 09-22-17, 08:57 AM
ray2047's Avatar
We need to know what wires are in your ceiling box. Please post a picture.
