2-Speed Fan Wiring
Old 09-23-17, 10:44 AM
D
2-Speed Fan Wiring
I received a 2-Speed fan from a friend as a basket case. He provided some photos of the switch before he disconnected it to help me reassemble it (?)<br />
<br />
I think this is right, but I wanted to check with someone who would actually know.
Old 09-23-17, 01:15 PM
Received 1,113 Votes on 1,033 Posts
Welcome to the forums.
In your pictures it looks like everything is connected with crimp caps. Is that wiring the way it was originally ? Are you just replacing the switch ?
Something doesn't look right as the run cap is only in one speed line.
Old 09-23-17, 01:35 PM
I was checking thru my diagrams and I found a three speed fan wiring diagram. Based on that.... the cap is connected to just the high speed fan wire. That means your diagram does appear to be correct.
D
The first image is my drawing of how I think it should be wired based on what I can garner from the photos that the donor of the fan took just before cutting off the switch. The crimp caps have been cut off and all the wires removed. I am attempting to put it back together.
We cross posted. Check my last reply.
Old 09-23-17, 04:56 PM
D
Thanks for the guidance sir.
