Fan did not work with this adaptor
Old 09-25-17, 04:11 AM
W
Question Fan did not work with this adaptor
https://imgur.com/a/xn3Dl
The first image above is fan's features, under it the adapter i connected to it.
Can you explain to me this whole situation detailed and tell me what kind of adapter should i use ?
Adapter was working with 12V DC Fan and i have no idea what that means on a fan
Old 09-25-17, 04:36 AM
L
Received 177 Upvotes on 152 Posts
That fan is rated AC 220-240V 50/60Hz. Meaning you have to feed AC power to it. Since minimum voltage is 220V, it won't be easy to use in the US unless you use it on 240V equipment.
Old 09-25-17, 04:37 AM
the_tow_guy's Avatar
Received 176 Upvotes on 138 Posts
The fan is 220v, the adapter is 110v. Won't work.
Old 09-25-17, 04:38 AM
Oops, missed the listed voltage as 110-240v.
Old 09-25-17, 05:08 AM
W
I am not ın US and our electricity is 220V output anyway. So what should i do. What do you mean by AC power ?
Old 09-25-17, 06:21 AM
W
Received 60 Upvotes on 52 Posts
The output on the adaptor is only 12 volts. The fan requires 220 volts.
Old 09-25-17, 08:43 AM
Received 3,422 Upvotes on 3,068 Posts
The fan requires the mains voltage to carefully be connected directly to it with no AC adapter.
Old 09-25-17, 10:26 AM
W
can you give me a link to carefull guidance of this ?
Old 09-25-17, 10:38 AM
The fan has two wires coming off of it. Put a plug on those two wires and plug it in.
