Wiring ten 50w outdoor LED fixtures
Old 09-26-17, 03:24 PM
Considering purchasing ten 50w outdoor LED fixtures (link with specs below) and wondering how to install in a 125 foot run. What wire/cable to use, wire in parallel, connectors to facilitate install, wire to a 15amp box (they are supposedly about 0.5amps/fixture)?
Thanks, partially clueless DIY-er.
https://www.dhgate.com/product/2-4gh...396994181.html
Old 09-26-17, 03:35 PM
Received 1,509 Votes on 1,396 Posts
Welcome to the forums.
Since that light is not set up for direct wiring..... I would use 1/2" EMT and set a weather proof junction box at each light. You could then use a short piece of rubber cord to connect the fixture to the box. You would pull three #14 wires...... white, black and green in the pipe.
